coq-club - Re: [Coq-Club] Coq classes don't work as expected!
chronological Thread
  • To: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coq classes don't work as expected!
  • Date: Sun, 06 Nov 2011 04:48:19 +0400
  • Envelope-from: porton AT yandex.ru
Oops, I noticed that the below works if I replace Structure -> Class.
But if I replace structures with classes, then the commented definition below
stops working:
Definition compose_relation_classes (f g: Relation) := (compose_graph
(mygraph f) (mygraph g)).
So either one or the other does not work. Coq type classes need a redesign!
06.11.2011, 04:24, "Victor Porton"
<porton AT narod.ru>:
> Classes.v:
> Structure Base := {
> ššset: Set
> RelTypes.v:
> Require Import Classes.
> Require Import sset2.
> Structure Relation := {
> ššrelation_is_base :> Base;
> šš(*mygraph: set->set->Prop*)
> ššmygraph: Set;
> ššis_rel: is_graph mygraph
> (*Definition compose_relation_classes (f g: Relation) := (compose_graph
> (mygraph f) (mygraph g)).*)
> Class Reflexive := {
> ššreflexive_is_relation :> Relation;
> ššis_reflexive: forall x:Set, ((inc x set)->(related mygraph x x))
> This produces the error:
> The term "set" has type "Base -> Set" while it is expected to have type
> "Set".
> Thus I see no way to specify that in the definition of the class Reflexive
> "set" should refer to the current instance of the class rather than to be
> considered as an un-applied function of type "Base -> Set".
> We need some good way to deal with this trouble. For instance, we may
> introduce a new keyword (self, this, our, etc.) which will denote the
> current class instance.
> In Reference Manual type classes are marked as an experimental feature. It
> is really so. Type classes do not work as expected in Coq 8.3pl2.
> I want to wait for the next version. Meanwhile I do not like to use Coq
> because its classes are broken.
> Victor Porton - http://portonvictor.org
