coq-club - Re: [Coq-Club] Coq classes don't work as expected!
chronological Thread
  • To: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coq classes don't work as expected!
  • Date: Sun, 06 Nov 2011 04:52:22 +0400
  • Envelope-from: porton AT yandex.ru
My proposal:
If a definition receives more than one argument of a class, the class should
behave as if it would be a structure.
This would make this code working:
Definition compose_relation_classes (f g: Relation) := (compose_graph
(mygraph f) (mygraph g)).
Experts, does my proposal sound good? Any alternative solutions?
06.11.2011, 04:48, "Victor Porton"
<porton AT narod.ru>:
> Oops, I noticed that the below works if I replace Structure -> Class.
> But if I replace structures with classes, then the commented definition
> below stops working:
> So either one or the other does not work. Coq type classes need a redesign!
> 06.11.2011, 04:24, "Victor Porton"
>> šClasses.v:
>> š[[[
>> šStructure Base := {
>> šššset: Set
>> š}.
>> š]]]
>> šRelTypes.v:
>> š[[[
>> šRequire Import Classes.
>> šRequire Import sset2.
>> šStructure Relation := {
>> šššrelation_is_base :> Base;
>> ššš(*mygraph: set->set->Prop*)
>> šššmygraph: Set;
>> šššis_rel: is_graph mygraph
>> š}.
>> š(*Definition compose_relation_classes (f g: Relation) := (compose_graph
>> (mygraph f) (mygraph g)).*)
>> šClass Reflexive := {
>> šššreflexive_is_relation :> Relation;
>> šššis_reflexive: forall x:Set, ((inc x set)->(related mygraph x x))
>> š}.
>> š]]]
>> šThis produces the error:
>> šThe term "set" has type "Base -> Set" while it is expected to have type
>> "Set".
>> šThus I see no way to specify that in the definition of the class
>> Reflexive "set" should refer to the current instance of the class rather
>> than to be considered as an un-applied function of type "Base -> Set".
>> šWe need some good way to deal with this trouble. For instance, we may
>> introduce a new keyword (self, this, our, etc.) which will denote the
>> current class instance.
>> šIn Reference Manual type classes are marked as an experimental feature.
>> It is really so. Type classes do not work as expected in Coq 8.3pl2.
>> šI want to wait for the next version. Meanwhile I do not like to use Coq
>> because its classes are broken.
>> š--
>> šVictor Porton - http://portonvictor.org
