- To: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq classes don't work as expected!
- Date: Sun, 06 Nov 2011 05:00:37 +0400
- Envelope-from: porton AT yandex.ru
Oh, I found a working solution, using @. But to find it was not trivial. We
need to update Coq code or at least to describe this trick in Coq
documentation:
Classes.v:
Class Base := {
set: Set
RelTypes.v"
Require Import Classes.
Require Import sset2.
Class Relation := {
relation_is_base :> Base;
(*mygraph: set->set->Prop*)
mygraph: Set;
is_rel: is_graph mygraph
Definition compose_relation_classes (f g: Relation) := (compose_graph
(@mygraph f) (@mygraph g)).
Class Reflexive := {
reflexive_is_relation :> Relation;
is_reflexive: forall x:Set, ((inc x set)->(related mygraph x x))
Class Symmetric := {
symmetric_is_relation :> Relation;
is_symmetric: forall x y:Set, ((related mygraph x y)<->(related mygraph y
x))
06.11.2011, 04:52, "Victor Porton"
<porton AT narod.ru>:
> My proposal:
> If a definition receives more than one argument of a class, the class
> should behave as if it would be a structure.
> This would make this code working:
> (mygraph f) (mygraph g)).
> Experts, does my proposal sound good? Any alternative solutions?
> 06.11.2011, 04:48, "Victor Porton"
>Â <porton AT narod.ru>:
>> šOops, I noticed that the below works if I replace Structure -> Class.
>> šBut if I replace structures with classes, then the commented definition
>> below stops working:
>> šDefinition compose_relation_classes (f g: Relation) := (compose_graph
>> šSo either one or the other does not work. Coq type classes need a
>> redesign!
>> š06.11.2011, 04:24, "Victor Porton"
>>> ššClasses.v:
>>> šš[[[
>>> ššStructure Base := {
>>> ššššset: Set
>>> šš}.
>>> šš]]]
>>> ššRelTypes.v:
>>> šš[[[
>>> ššRequire Import Classes.
>>> ššRequire Import sset2.
>>> ššStructure Relation := {
>>> ššššrelation_is_base :> Base;
>>> šššš(*mygraph: set->set->Prop*)
>>> ššššmygraph: Set;
>>> ššššis_rel: is_graph mygraph
>>> šš}.
>>> šš(*Definition compose_relation_classes (f g: Relation) := (compose_graph
>>> (mygraph f) (mygraph g)).*)
>>> ššClass Reflexive := {
>>> ššššreflexive_is_relation :> Relation;
>>> ššššis_reflexive: forall x:Set, ((inc x set)->(related mygraph x x))
>>> šš}.
>>> šš]]]
>>> ššThis produces the error:
>>> ššThe term "set" has type "Base -> Set" while it is expected to have type
>>> "Set".
>>> ššThus I see no way to specify that in the definition of the class
>>> Reflexive "set" should refer to the current instance of the class rather
>>> than to be considered as an un-applied function of type "Base -> Set".
>>> ššWe need some good way to deal with this trouble. For instance, we may
>>> introduce a new keyword (self, this, our, etc.) which will denote the
>>> current class instance.
>>> ššIn Reference Manual type classes are marked as an experimental feature.
>>> It is really so. Type classes do not work as expected in Coq 8.3pl2.
>>> ššI want to wait for the next version. Meanwhile I do not like to use Coq
>>> because its classes are broken.
>>> šš--
>>> ššVictor Porton - http://portonvictor.org
>> š--
- [Coq-Club] Coq classes don't work as expected!, Victor Porton
- Re: [Coq-Club] Coq classes don't work as expected!,
Victor Porton
Victor Porton
- Re: [Coq-Club] Coq classes don't work as expected!, Victor Porton
- Re: [Coq-Club] Coq classes don't work as expected!, Vincent Siles
Victor Porton
Victor Porton
