- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Victor Porton <porton AT narod.ru>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] What is the meaning of dependent record conditions?
- Date: Mon, 7 Nov 2011 19:14:35 -0500
Set Printing All.
Record C_record := {
x_record: nat;
cond_record: x_record = 0
Class C_class := {
x_class: nat;
cond_class: x_class = 0
Print C_record.
(*Inductive C_record : Type :=
Build_C_record : forall x_record : nat, @eq nat x_record O -> C_record
For Build_C_record: Argument scopes are [nat_scope _]*)
Print C_class.
(*Inductive C_class : Type :=
Build_C_class : forall x_class : nat, @eq nat x_class O -> C_class
For Build_C_class: Argument scopes are [nat_scope _]
About cond_record.
(*cond_record : forall c : C_record, @eq nat (x_record c) O
cond_record is transparent
Expands to: Constant Top.cond_record*)
About cond_class.
(*cond_class : forall C_class : C_class, @eq nat (@x_class C_class) O
Argument C_class is implicit and maximally inserted
cond_class is transparent
Expands to: Constant Top.cond_class
Print cond_record.
(*cond_record =
fun c : C_record =>
match c as c0 return (@eq nat (x_record c0) O) with
| Build_C_record x_record cond_record => cond_record
end
: forall c : C_record, @eq nat (x_record c) O*)
Print cond_class.
(*cond_class =
fun C_class0 : C_class =>
match C_class0 as C_class return (@eq nat (@x_class C_class) O) with
| Build_C_class x_class cond_class => cond_class
end
Argument C_class is implicit and maximally inserted*)
Goal forall c, c.(cond_record) = cond_record c.
Proof. reflexivity. Qed.
- [Coq-Club] What is the meaning of dependent record conditions?, Victor Porton
- Re: [Coq-Club] What is the meaning of dependent record conditions?,
Victor Porton
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Alexandre Pilkiewicz
- Message not available
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Daniel Schepler
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Carlos Simpson
Victor Porton
- [Coq-Club] Re: What is the meaning of dependent record conditions?, Stefan Monnier
