- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re: What is the meaning of dependent record conditions?
- Date: Mon, 07 Nov 2011 22:09:27 -0500
- Cancel-lock: sha1:XMnkjRXEFguwXsPS9rK4Eyf3Wy8=
> This tells that [cond] is a function which receives an argument of type C.
> But what is it meanings?
It means that it returns the proof object stored under the `cond' field.
> If the argument x is of type C, it is already
> verified that [cond x] is true!
Are you confusing booleans with objects of type Set, maybe?
Stefan
- [Coq-Club] What is the meaning of dependent record conditions?, Victor Porton
- Re: [Coq-Club] What is the meaning of dependent record conditions?,
Alexandre Pilkiewicz
Victor Porton
- Message not available
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Daniel Schepler
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Carlos Simpson
- Re: [Coq-Club] What is the meaning of dependent record conditions?, Alexandre Pilkiewicz
Victor Porton
- [Coq-Club] Re: What is the meaning of dependent record conditions?, Stefan Monnier
