coq-club - Re: [Coq-Club] What is the meaning of dependent record conditions?
chronological Thread
  • To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
  • Cc: Victor Porton <porton AT narod.ru>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] What is the meaning of dependent record conditions?
  • Date: Mon, 7 Nov 2011 19:05:51 -0800
On Mon, Nov 7, 2011 at 6:08 PM, Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org> wrote:
2011/11/7 Victor Porton <porton AT narod.ru>:
> The problem stays if we use simple Structures.
> Record S := {
>  x_record: nat;
>  cond_record: x_record = 0
> This creates a [cond_record] function which is in my opinion is entirely meaningless because it takes an argument of type C and returns True iff it is of type C, that is always return True.
Any member of your type S is a dependent pair of an integer and a
proof that this integer is equal to zero. The keyword "Record",
contrary to the simpler one Inductive, alors automatically defines to
functions, x_record and cond_record that project that pair (you can
think of them as being fst and snd, but for the type S. That is what I
showed in my precedent exemple, but I can show it again:
It might also help to think of cond_record as the result, automatically proved by Coq, that whenever s is an element of type S, then the x value of s is in fact equal to 0.  So, for example, you can apply this using:
Lemma Sx_plus_idem: forall s:S, x_record s + x_record s = x_record s.
Proof.
intros.
rewrite cond_record.
reflexivity.
Qed.
The interpretation Alexandre suggested relies on an understanding of the Howard-Curry correspondence, which underlies the meta-theory of Coq.  It will eventually be very useful to gain this understanding, as it allows you to do many things more concisely.  However, it does take a while to get used to it.
Daniel Schepler
