- To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A beginner question in class instances
- Date: Wed, 09 Nov 2011 03:27:52 +0400
- Envelope-from: porton AT yandex.ru
09.11.2011, 03:19, "Alexandre Pilkiewicz"
<alexandre.pilkiewicz AT polytechnique.org>:
> On Tue, Nov 8, 2011 at 5:50 PM, Victor Porton
>Â <porton AT narod.ru>
> wrote:
>> š(*
>> šWhat's wrong with the following .v file which does not verify:
>> šHow to correct it?
>> š*)
>> šClass C := {
>> ššnum: nat;
>> ššcond: num=0
>> š}.
>> šInstance C2: C := { num:=0 }.
> When I reach this point, I have to prove "0 = 0". Do you really have
> difficulties proving "0 = 0"? Maybe Type Classes should wait.
The difficulty is not to prove 0 = 0 but with getting the "num" field of the
current class instance in the proof of the instance.
If I just remove "have (num C2=0) using tauto" it verifies, but my point is
not just to verify the theory but to study how to write proofs of type
classes validity.
Well, Alexandre, you are right supposing that my knowledge of tactics is
weak. I want to learn more about tactics, but only after I will know how to
denote the current instance in an instance proof.
> Proof. reflexivity. Qed.
>> šproof.
>> ššhave (num C2=0) using tauto.
>> šend proof.
>> š--
>> šVictor Porton - http://portonvictor.org
- [Coq-Club] A beginner question in class instances, Victor Porton
- Re: [Coq-Club] A beginner question in class instances,
- Re: [Coq-Club] A beginner question in class instances, Victor Porton
Victor Porton
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Alexandre Pilkiewicz
Victor Porton
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Jelle Herold
- <Possible follow-ups>
- Fwd: [Coq-Club] A beginner question in class instances, Victor Porton
