- To: coq-club AT inria.fr
- Subject: Re: Fwd: [Coq-Club] A beginner question in class instances
- Date: Wed, 09 Nov 2011 01:24:38 +0100
Hi Victor,
On 11/09/2011 01:12 AM, Victor Porton wrote:
So something like this maybe?
Class C := {
num: nat;
cond: num=0
Lemma is_nul `(C) : num = 0.
Proof.
apply cond.
Qed.
Check is_nul.
is_nul
: forall H : C, num = 0
It does not answer my question. My question was about instance proofs, but there are no
keyword "Instance" in your example. I want an example of an instance proof.
You want to proof that C2 with num=2 is an instance of C.
In order to do that you need to specify all the fields. You only specified the "num" field, but not the "cond" field (which is ok).
Proof mode is smart enough to figure this out, so when you write
Instance C2: C := { num:=0 }.
Proof.
Your goal is automatically set to proving "cond", which states "num=0" which for this instance gives you "0=0" so that is why you need to proof that.
So alternatively you could write (this makes sense for more complicated classes)
Lemma silly : 0 = 0.
Proof. reflexivity. Qed.
Instance C2 : C := { num = 0; cond = silly }.
I think, I should do these exercises (but now it's late night here).
I agree, take you time.
Thanks for the exercises. I will look into them.
This is my last message sent before I look into exercises.
Very well, I'm happy about that. It is really a lot of work and new concepts so don't expect to finish them in a day (or a week.. month...).
Also you should download SF and/or CPDT and then load them in CoqIDE and do the exercises in the file. Hands on, like paper mathematics, don't just look at them.
- [Coq-Club] A beginner question in class instances, Victor Porton
- Re: [Coq-Club] A beginner question in class instances,
Alexandre Pilkiewicz
Victor Porton
Victor Porton
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Alexandre Pilkiewicz
Victor Porton
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Jelle Herold
Victor Porton
- <Possible follow-ups>
- Fwd: [Coq-Club] A beginner question in class instances,
Victor Porton
- Re: Fwd: [Coq-Club] A beginner question in class instances, Jelle Herold
