- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Victor Porton <porton AT narod.ru>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A beginner question in class instances
- Date: Tue, 8 Nov 2011 18:32:57 -0500
2011/11/8 Victor Porton
<porton AT narod.ru>:
> The difficulty is not to prove 0 = 0 but with getting the "num" field of
> the current class instance in the proof of the instance.
> If I just remove "have (num C2=0) using tauto" it verifies, but my point is
> not just to verify the theory but to study how to write proofs of type
> classes validity.
C2 does not exist yet, you are defining it. So of course you can't use "num
C2"!
> Well, Alexandre, you are right supposing that my knowledge of tactics is
> weak. I want to learn more about tactics, but only after I will know how to
> denote the current instance in an instance proof.
Still.... "0=0" should come first.
Alexandre
- [Coq-Club] A beginner question in class instances, Victor Porton
- Re: [Coq-Club] A beginner question in class instances,
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Alexandre Pilkiewicz
Victor Porton
Victor Porton
Victor Porton
Victor Porton
- Re: [Coq-Club] A beginner question in class instances, Jelle Herold
Victor Porton
- <Possible follow-ups>
- Fwd: [Coq-Club] A beginner question in class instances, Victor Porton
