- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Victor Porton <porton AT narod.ru>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why this does not verify?
- Date: Mon, 14 Nov 2011 09:54:37 -0500
I guess the problem is that the expression "C2" of type "C" cannot be
applied to the term "ax2" : "forall obj : C, Q num".
Cheers
Alexandre
On Mon, Nov 14, 2011 at 9:41 AM, Victor Porton
wrote:
> Hypothesis P: nat->Prop.
> Hypothesis Q: nat->Prop.
> Axiom Eq: forall x:nat, P(x)<->Q(x).
> Class C := {
> šnum: nat;
> šcond: P num
> Section sect.
> šHypothesis Other: forall obj:C, Q num.
> šInstance C2: C := { num:=0 }.
> šProof. Admitted.
> End sect.
> Axiom ax2: forall obj:C, Q num.
> Definition C3 := C2(ax2).
- [Coq-Club] Why this does not verify?, Victor Porton
- Re: [Coq-Club] Why this does not verify?, Alexandre Pilkiewicz
- <Possible follow-ups>
- Fwd: [Coq-Club] Why this does not verify?,
Victor Porton
- Re: Fwd: [Coq-Club] Why this does not verify?,
Adam Chlipala
- Re: [Coq-Club] Why this does not verify?, Victor Porton
- Re: Fwd: [Coq-Club] Why this does not verify?, Adam Chlipala
Adam Chlipala
- Re: [Coq-Club] Why this does not verify?, Paolo Herms
