- To: Victor Porton <porton AT narod.ru>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: Fwd: [Coq-Club] Why this does not verify?
- Date: Mon, 14 Nov 2011 10:17:26 -0500
I'm surprised that [C2] has type [C], so I think Victor has a legitimate point here. The usual section behavior rules imply to me that [C2] should be parametrized over [Other].
On the other hand, the specific proposition used for [Other] is dangerously close to inconsistent (easily implies [False] for any interesting choice of [Q]), so there may be other serious issues in the code.
Victor Porton wrote:
See also this my bug report:
http://www.lix.polytechnique.fr/coq/bugs/show_bug.cgi?id=2642
14.11.2011, 18:58, "Thomas
Braibant"<thomas.braibant AT gmail.com>:
- C2 has type "C"
- whatever the type of ax2, you cannot apply C to it, because "C" is
not a function type.
- it happens that "ax2 C" as type "Q num", but since your whole script
does not has much sense to me, I cannot assume that it was what you
wanted to write.
Cheers,
thomas
On Mon, Nov 14, 2011 at 3:41 PM, Victor
Porton<porton AT narod.ru>
wrote:
Hypothesis P: nat->Prop.
Hypothesis Q: nat->Prop.
Axiom Eq: forall x:nat, P(x)<->Q(x).
Class C := {
num: nat;
cond: P num
Section sect.
Hypothesis Other: forall obj:C, Q num.
Instance C2: C := { num:=0 }.
Proof. Admitted.
End sect.
Axiom ax2: forall obj:C, Q num.
Definition C3 := C2(ax2).
- [Coq-Club] Why this does not verify?, Victor Porton
- Re: [Coq-Club] Why this does not verify?, Alexandre Pilkiewicz
- <Possible follow-ups>
- Fwd: [Coq-Club] Why this does not verify?,
Victor Porton
- Re: Fwd: [Coq-Club] Why this does not verify?, Adam Chlipala
- Re: [Coq-Club] Why this does not verify?, Victor Porton
- Re: [Coq-Club] Why this does not verify?, Paolo Herms
