coq-club - Re: [Coq-Club] Why this does not verify?
chronological Thread
  • To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why this does not verify?
  • Date: Mon, 14 Nov 2011 19:25:43 +0400
  • Envelope-from: porton AT yandex.ru
The most proper solution would be to introduce special mode such that when it
turned on, every section variable would always generalize, even if it is not
used.
I propose this syntax:
Set AllSectionVariables True.
(maybe not the best syntax, but you've got the idea).
Maybe it will be useful to turn it on by default in a future version of Coq?
We need also to put a comment with agreed solution to
http://www.lix.polytechnique.fr/coq/bugs/show_bug.cgi?id=2642
14.11.2011, 19:21, "Alexandre Pilkiewicz"
<alexandre.pilkiewicz AT polytechnique.org>:
> 2011/11/14 Adam Chlipala
> <adamc AT csail.mit.edu>:
>>  I'm surprised that [C2] has type [C], so I think Victor has a legitimate
>>  point here.  The usual section behavior rules imply to me that [C2] should
>>  be parametrized over [Other].
> No, definitions in section only generalize the Variables that are used
> in the body of the definition (or its type). When you admit the proof,
> you don't use Other, so it is not generalized. Changing this would
> break tons of codes!
> That being said, when defining a lemma, it would be nice to be able to
> specify which variable are "used" whether they are or not. This is
> useful when you want to accelerate compilation of your .v files by
> removing the body of all proofs and replacing them by Admitted. But
> the issue is known, and Arthur Charguéraud already proposed solution
> to it.
> Cheers,
> Alexandre
>>  On the other hand, the specific proposition used for [Other] is
>> dangerously
>>  close to inconsistent (easily implies [False] for any interesting choice
>> of
>>  [Q]), so there may be other serious issues in the code.
>>  Victor Porton wrote:
>>>  See also this my bug report:
>>>  14.11.2011, 18:58, "Thomas
>>> Braibant"<thomas.braibant AT gmail.com>:
>>>>   - C2 has type "C"
>>>>   - whatever the type of ax2, you cannot apply C to it, because "C" is
>>>>   not a function type.
>>>>   - it happens that "ax2 C" as type "Q num", but since your whole script
>>>>   does not has much sense to me, I cannot assume that it was what you
>>>>   wanted to write.
>>>>   Cheers,
>>>>   thomas
>>>>   On Mon, Nov 14, 2011 at 3:41 PM, Victor
>>>> Porton<porton AT narod.ru>
>>>>   wrote:
>>>>>    Hypothesis P: nat->Prop.
>>>>>    Hypothesis Q: nat->Prop.
>>>>>    Axiom Eq: forall x:nat, P(x)<->Q(x).
>>>>>    Class C := {
>>>>>     num: nat;
>>>>>     cond: P num
>>>>>    Section sect.
>>>>>     Hypothesis Other: forall obj:C, Q num.
>>>>>     Instance C2: C := { num:=0 }.
>>>>>     Proof. Admitted.
>>>>>    End sect.
>>>>>    Axiom ax2: forall obj:C, Q num.
>>>>>    Definition C3 := C2(ax2).
Victor Porton - http://portonvictor.org
