coq-club - [Coq-Club] Reasons for use = instead of <->
chronological Thread
  • To: Carlos Simpson <carlos.simpson AT unice.fr>, jose.grimm AT sophia.inria.fr
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Reasons for use = instead of <->
  • Date: Thu, 17 Nov 2011 20:30:28 +0400
  • Envelope-from: porton AT yandex.ru
In Carlos Simpson's ZF theory there was used = instead of <-> for the reason
mentioned in the following comment:
axioms.v:
(*** the following axioms can be obtained from the Ensembles library but we
include it here
as an axiom; it is used for convenience, allowing us to replace iff by
equality so as to
be able to rewrite using equality of propositions
(***) Axiom iff_eq : forall P Q : Prop, (P -> Q) -> (Q -> P) -> P = Q.
Jose Grimm's GAIA inherited this mode of expressing equality for
propositions, as his work was based on the work of Carlos Simpson.
Now there exists:
Require Import Setoid.
It allows rewrite to work with <->.
Now we need to make a decision: Should we switch to using Setoid from
standard library and replace every = comparing propositions with <->?
Please all interested parties make a comment.
Also: If we'll decide to replace all such occurrences of = with <-> who will
do the job of searching all occurrences? I may do it gradually replacing only
these occurrences which I may encountered on my way of doing a derived
theory. (It may be somehow hard for me, I'm yet weak in imperative proofs
scripts as I instead decided to learn the declarative proof mode.)
Victor Porton - http://portonvictor.org
