- To: roconnor AT theorem.ca
- Cc: Carlos Simpson <Carlos.Simpson AT unice.fr>, Andrew Cave <acave1 AT cs.mcgill.ca>, Victor Porton <porton AT narod.ru>, Thorsten Altenkirch <txa AT cs.nott.ac.uk>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] quotients
- Date: Thu, 17 Nov 2011 17:22:31 +0100
Hi Russell,
Olov Wilander shows that PERs, unlike setoids, have *given* pullbacks.
That is, pullbacks respect equalities.
http://urn.kb.se/resolve?urn=urn:nbn:se:uu:diva-159876
In fact, all the basic constructions are given. This may be related to
what you are suggesting?
Best,
Bas
On Thu, Nov 10, 2011 at 5:47 PM,
<roconnor AT theorem.ca>
wrote:
> On Wed, 9 Nov 2011, Carlos Simpson wrote:
>> Dear Russell,
>> Thanks, that's illuminating. I guess the question which can make us
>> uneasy about using setoids, is whether it causes too much extra effort to
>> prove that all functions are compatible all the time? That kind of fear
>> does
>> sometimes prove to be overblown.
> The amount of work needed to prove that functions are respectful is exactly
> the amount of work needed to show that a function is well-defined using
> quotients (ie the work needed to satisfy the hypothesis of
> ZornsLemma.Quotients.induced_fuction). Then some sort of type-class
> mechanism needs to take over to prove that compositions of respectful
> functions are respectful.
>> One imagines that all of the CIC operations we can do on types, need to be
>> done by hand for setoids. Is it the case that you actually end up having
>> only a small number of these to do in practice? ---Carlos
> There is something to this point. You need need to write a library to make
> products of setoid, and disjoint unions of setoids, and setoid function
> spaces (*). However, I never really had a problem with this because we have
> to do this sort of thing all the time anyways. So, for example, when doing
> my work on metric spaces I needed to define a metric for the product of two
> metric spaces, and a metric for functions between metric spaces, etc. Since
> I had to all this work anyways, I didn't find it particularly burdensome to
> define these operations on setoids while I was at it.
> (*) Actually I did discover some annoyance with setoids and function spaces.
> You need to put a setoid structure on a sigma-type of functions that are
> respectful. What I discovered was that everything would probably be better
> if PERs were used instead of setoids. The PER of functions between Setoids
> is exactly what you expect:
> f ~~ g := forall x y, x == y -> f x == g y
> And we immediately get that a function f is respectful when f ~~ f. And
> this definition extends to the PER of functions between PERs
> f ~~ g := forall x y, x ~~ y -> f x ~~ g y
> I spent a while slogging through this PER stuff and every obstacle I
> encountered eventually yielded to an elegant solution. I suspect that the
> experts on PERs already knew all this stuff I was discovering. Unfortunately
> at the time (several years ago) I couldn't quite get the support out of
> Mathieu's type class mechanism that I needed to make this seamless. I
> suspect it would be easier today or one could use Canonical Structures
> instead. I would encourage the development and use of PERs instead of
> setoids.
> Russell O'Connor <http://r6.ca/>
> ``All talk about `theft,''' the general counsel of the American Graphophone
> Company wrote, ``is the merest claptrap, for there exists no property in
> ideas musical, literary or artistic, except as defined by statute.''
- Re: [Coq-Club] I'm against setoids and pro ZF, (continued)
Matthieu Sozeau
- Re: [Coq-Club] I'm against setoids and pro ZF, Thorsten Altenkirch
roconnor
- Re: [Coq-Club] quotients,
Carlos Simpson
- Re: [Coq-Club] quotients, Andrew Cave
roconnor
Carlos Simpson
roconnor
Carlos Simpson
- Re: [Coq-Club] quotients, roconnor
- Re: [Coq-Club] quotients, Bas Spitters
- Re: [Coq-Club] quotients, Andrej Bauer
- Re: [Coq-Club] quotients, Peter Vincent Homeier
Carlos Simpson
roconnor
Carlos Simpson
- Re: [Coq-Club] quotients, Daniel Schepler
Carlos Simpson
Matthieu Sozeau
- Re: [Coq-Club] I'm against setoids and pro ZF, Michael Shulman
