coq-club - Re: [Coq-Club] CiC without elim restriction
chronological Thread
  • To: Gert Smolka <smolka AT ps.uni-saarland.de>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] CiC without elim restriction
  • Date: Mon, 28 Nov 2011 11:31:49 -0500
At the least, Zhaohui Luo's book (Computation and Reasoning: A Type
Theory for Computer Science) describing ECC and UTT notes the
inconsistency of strong impredicative sums. They let you do things
like:
    { P : Prop | True } : Prop
But { P : Prop | True } is equivalent to Prop if you can project out
the first component, giving you essentially
    Prop : Prop
Which is known to cause problems.
To prevent this, you need to restrict the elimination rules for these
impredicative sums in some way. I assume that's the sort of
restriction you were referring to?
Luo's thesis (which covers just ECC) may also have the note, and it's
a little more readily available than the book. I'm unsure of any other
references.
-- Dan
On Mon, Nov 28, 2011 at 10:47 AM, Gert Smolka
 wrote:
> Is the calculus of inductive constructions with impredicative Prop and
> without the elim restriction consistent?  What is the standard reference
> for this question?  Thanks, Gert
