- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CiC without elim restriction
- Date: Mon, 28 Nov 2011 17:51:43 +0100
On 11/28/2011 05:32 PM, Dan Doel wrote:
At the least, Zhaohui Luo's book (Computation and Reasoning: A Type
Theory for Computer Science) describing ECC and UTT notes the
inconsistency of strong impredicative sums. They let you do things
like:
{ P : Prop | True } : Prop
But { P : Prop | True } is equivalent to Prop if you can project out
the first component, giving you essentially
Prop : Prop
Which is known to cause problems.
To prevent this, you need to restrict the elimination rules for these
impredicative sums in some way. I assume that's the sort of
restriction you were referring to?
Maybe this is implicit in what you are saying but let me just emphasize that only *big* impredicative sums (i.e. with at least one constructor argument type not in Prop, like in your example) are inconsistent.
Small impredicative sums like { x:nat | P x } could have unrestricted eliminations (be aware that this contradicts proof-irrelevance and excluded-middle). This can be experimented with by mapping all Prop notions to their Set counterpart (ex -> sig, or -> sum, etc.) and using Coq with the -impredicative-set option.
The consistency of Coq with -impredicative-set and just one (and a half) universe is proved in Benjamin Werner's PhD. Don't know of any extension of this result to the full Type hierarchy, but it is believed to hold.
Bruno.
Bruno Barras Typical team - INRIA Saclay
LIX - Ecole Polytechnique 91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57 Fax: +33 1 69 33 30 14
- [Coq-Club] CiC without elim restriction, Gert Smolka
- Re: [Coq-Club] CiC without elim restriction, Dan Doel
- Message not available
- Re: [Coq-Club] CiC without elim restriction, Bruno Barras
