- To: Dan Doel <dan.doel AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CiC without elim restriction
- Date: Tue, 29 Nov 2011 12:47:30 +0100
On 11/28/2011 08:44 PM, Dan Doel wrote:
On Mon, Nov 28, 2011 at 11:51 AM, Bruno
Barras<bruno.barras AT inria.fr>
wrote:
On 11/28/2011 05:32 PM, Dan Doel wrote:
At the least, Zhaohui Luo's book (Computation and Reasoning: A Type
Theory for Computer Science) describing ECC and UTT notes the
inconsistency of strong impredicative sums. They let you do things
like:
{ P : Prop | True } : Prop
But { P : Prop | True } is equivalent to Prop if you can project out
the first component, giving you essentially
Prop : Prop
Which is known to cause problems.
To prevent this, you need to restrict the elimination rules for these
impredicative sums in some way. I assume that's the sort of
restriction you were referring to?
Maybe this is implicit in what you are saying but let me just emphasize that
only *big* impredicative sums (i.e. with at least one constructor argument
type not in Prop, like in your example) are inconsistent.
Small impredicative sums like { x:nat | P x } could have unrestricted
eliminations (be aware that this contradicts proof-irrelevance and
excluded-middle). This can be experimented with by mapping all Prop notions
to their Set counterpart (ex -> sig, or -> sum, etc.) and using Coq with the
-impredicative-set option.
Yes. That doesn't really even register as impredicative to me.
I should have said "small sum in an impredicative sort". It's not always clear what the impredicative word applies to: is it each feature that is considered impredicative or not, or is it the whole theory ?
What is clear to me is that the impredicative product types of Set have a global impact on the theory. For instance it is incompatible with interpreting each predicative product (in Type) as the set of set-theoretic functions (that's the Chicli-Pottier-Simpson paradox).
Bruno.
Bruno Barras Typical team - INRIA Saclay
LIX - Ecole Polytechnique 91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57 Fax: +33 1 69 33 30 14
- [Coq-Club] CiC without elim restriction, Gert Smolka
- Re: [Coq-Club] CiC without elim restriction, Dan Doel
- Message not available
Bruno Barras
- Re: [Coq-Club] CiC without elim restriction, Bruno Barras
Bruno Barras
