- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] overloading notation
- Date: Tue, 13 Dec 2011 10:41:03 +0100
Hello.
So I would like to use the same syntactical operator for different
types. For instance,
Inductive foo : X :=
| Cons : x -> y -> z -> foo.
And now assume that the projections are properly defined, and then
Notation "e '->x' " := (projectionX e) (at level 80, right associativity).
Now, I want to define another inductive, and use the same "->"
operator, but that will not work unless I explicitly use scopes.
Something like:
associativity) : foo_scope.
But then again, that really does not absolutely solve my problem since
now I _explicitly_ need to open/close scopes, which means that I
cannot use the intended overloaded operator "->" in the same
context...
So, how does one achieve that? :-)
thank you!
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a
terrible life choice.
- [Coq-Club] overloading notation, Nuno Gaspar
- [Coq-Club] Re: overloading notation, Nuno Gaspar
- Re: [Coq-Club] overloading notation, AUGER Cédric
- Message not available
Nuno Gaspar
- Re: [Coq-Club] overloading notation, Arnaud Spiwack
- Re: [Coq-Club] overloading notation, Tom Prince
Nuno Gaspar
