- To: Nuno Gaspar <nmpgaspar AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] overloading notation
- Date: Tue, 13 Dec 2011 16:34:18 +0100
Le Tue, 13 Dec 2011 10:41:03 +0100,
Nuno Gaspar
a écrit :
> Hello.
> So I would like to use the same syntactical operator for different
> types. For instance,
> Inductive foo : X :=
> | Cons : x -> y -> z -> foo.
> And now assume that the projections are properly defined, and then
> Notation "e '->x' " := (projectionX e) (at level 80, right
> associativity). ...
> Now, I want to define another inductive, and use the same "->"
> operator, but that will not work unless I explicitly use scopes.
> Something like:
> associativity) : foo_scope.
> But then again, that really does not absolutely solve my problem since
> now I _explicitly_ need to open/close scopes, which means that I
> cannot use the intended overloaded operator "->" in the same
> context...
> So, how does one achieve that? :-)
> thank you!
Maybe you could put your two inductives into a same type class?
Class Arrow (X:Type) (Y:Type) := {
arrow : X -> Y
Instance AX1 : Arrow X x := { arrow := projectionX }.
Instance AX1 : Arrow Y y := { arrow := projectionY }.
Notation "e '->x'" := (arrowX e) (at level 80, right associativity).
But I wouldn't recommend such a notation, since I would fear to confuse
the parser.
- [Coq-Club] overloading notation, Nuno Gaspar
- [Coq-Club] Re: overloading notation, Nuno Gaspar
- Re: [Coq-Club] overloading notation, AUGER Cédric
- Message not available
Nuno Gaspar
- Re: [Coq-Club] overloading notation, Arnaud Spiwack
- Re: [Coq-Club] overloading notation, Tom Prince
Nuno Gaspar
