coq-club - Re: [Coq-Club] overloading notation
chronological Thread
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: Nuno Gaspar <nmpgaspar AT gmail.com>
  • Cc: AUGER Cédric <Cedric.Auger AT lri.fr>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] overloading notation
  • Date: Thu, 15 Dec 2011 15:19:28 +0100
You may be interested in this command also: http://coq.inria.fr/doc/Reference-Manual015.html#@command261
Now, maybe you should explain more precisely what kind of behaviour you would expect. So that you get more precise help.
Arnaud Spiwack
On 13 December 2011 16:54, Nuno Gaspar <nmpgaspar AT gmail.com> wrote:
2011/12/13 AUGER Cédric <Cedric.Auger AT lri.fr>
Le Tue, 13 Dec 2011 10:41:03 +0100,
Nuno Gaspar <nmpgaspar AT gmail.com> a écrit :
> Hello.
> So I would like to use the same syntactical operator for different
> types. For instance,
> Inductive foo : X :=
>    | Cons : x -> y -> z -> foo.
> And now assume that the projections are properly defined, and then
> Notation "e '->x' " := (projectionX e) (at level 80, right
> associativity). ...
> Now, I want to define another inductive, and use the same "->"
> operator, but that will not work unless I explicitly use scopes.
> Something like:
> associativity) : foo_scope.
> But then again, that really does not absolutely solve my problem since
> now I _explicitly_ need to open/close scopes, which means that I
> cannot use the intended overloaded operator "->" in the same
> context...
> So, how does one achieve that? :-)
> thank you!
Maybe you could put your two inductives into a same type class?
From [*], The status of Type Classes is experimental. :)
Anyway, I'll look into it. thank you.
[*]http://coq.inria.fr/refman/Reference-Manual024.html
Class Arrow (X:Type) (Y:Type) := {
 arrow : X -> Y
Instance AX1 : Arrow X x := { arrow := projectionX }.
Instance AX1 : Arrow Y y := { arrow := projectionY }.
Notation "e '->x'" := (arrowX e) (at level 80, right associativity).
But I wouldn't recommend such a notation, since I would fear to confuse
the parser.
Ok, I guess i'm stuck with the % notation then.
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
