coq-club - Re: [Coq-Club] Executability of Function Command
chronological Thread
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: jonathan.heras AT unirioja.es
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Executability of Function Command
  • Date: Tue, 20 Dec 2011 16:59:36 +0100
Hi Jonathan,
try replacing Qed with Defined. It should allow your function to evaluate.
Cheers,
Vincent
2011/12/20
<jonathan.heras AT unirioja.es>:
> Dear all,
> I would like to know if it is possible to execute a recursive function which
> has been defined using the Function Command.
> For instance, if we have defined the following function (which merges two
> lists)
> Function merge2 (p:list Z*list Z)
> {measure (fun p=>(length (fst p))+(length (snd p)))} : list Z :=
> match p with
> | (nil,l) => l
> | (l,nil) => l
> | (x::xs,y::ys) => if Z_lt_ge_dec x y
> then x::(merge2 (xs,y::ys))
> else y::(merge2 (x::xs,ys))
> end.
> intros.
> simpl; auto with arith.
> intros.
> Qed.
> and now we are interested in computing
> Eval compute in merge2 ((1::3::5::nil),(2::4::6::nil)).
> In this case, the result that I obtain is
> let (v, _) :=
>           merge2_terminate
>             (1 :: 3 :: 5 :: Datatypes.nil, 2 :: 4 :: 6 :: Datatypes.nil) in
>       v
>     : list Z
> when I was expecting (1::2::3::4::5::6::nil).
> So, is it impossible to compute with a recursive function defined using
> Function?
> Thank you in advance.
