- From: J�nathan Heras <jonathan.heras AT unirioja.es>
- To: Vincent Siles <vincent.siles AT ens-lyon.org>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Executability of Function Command
- Date: Tue, 20 Dec 2011 17:01:54 +0100
Thanks, it worked perfectly.
Sincerely.
Jónathan
El 20/12/11 16:59, Vincent Siles escribió:
Hi Jonathan,
try replacing Qed with Defined. It should allow your function to evaluate.
Cheers,
Vincent
2011/12/20<jonathan.heras AT unirioja.es>:
Dear all,
I would like to know if it is possible to execute a recursive function which
has been defined using the Function Command.
For instance, if we have defined the following function (which merges two
lists)
Function merge2 (p:list Z*list Z)
{measure (fun p=>(length (fst p))+(length (snd p)))} : list Z :=
match p with
| (nil,l) => l
| (l,nil) => l
| (x::xs,y::ys) => if Z_lt_ge_dec x y
then x::(merge2 (xs,y::ys))
else y::(merge2 (x::xs,ys))
end.
intros.
simpl; auto with arith.
intros.
Qed.
and now we are interested in computing
Eval compute in merge2 ((1::3::5::nil),(2::4::6::nil)).
In this case, the result that I obtain is
let (v, _) :=
merge2_terminate
(1 :: 3 :: 5 :: Datatypes.nil, 2 :: 4 :: 6 :: Datatypes.nil) in
v
: list Z
when I was expecting (1::2::3::4::5::6::nil).
So, is it impossible to compute with a recursive function defined using
Function?
Thank you in advance.
- [Coq-Club] Executability of Function Command, jonathan . heras
- Re: [Coq-Club] Executability of Function Command,
Vincent Siles
- Re: [Coq-Club] Executability of Function Command, Jónathan Heras
- Re: [Coq-Club] Executability of Function Command, Pierre Courtieu
Vincent Siles
