- To: J�nathan Heras <jonathan.heras AT unirioja.es>
- Cc: Vincent Siles <vincent.siles AT ens-lyon.org>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Executability of Function Command
- Date: Tue, 20 Dec 2011 19:25:36 +0100
Notice also that you can use merge2_equation to rewrite instead of
computing (if you are trying to to prove thing on unclosed terms).
P.
2011/12/20 Jónathan Heras
<jonathan.heras AT unirioja.es>:
> Thanks, it worked perfectly.
> Sincerely.
> Jónathan
> El 20/12/11 16:59, Vincent Siles escribió:
>> Hi Jonathan,
>> try replacing Qed with Defined. It should allow your function to evaluate.
>> Cheers,
>> Vincent
>>Â 2011/12/20<jonathan.heras AT unirioja.es>:
>>> Dear all,
>>> I would like to know if it is possible to execute a recursive function
>>> which
>>> has been defined using the Function Command.
>>> For instance, if we have defined the following function (which merges two
>>> lists)
>>> Function merge2 (p:list Z*list Z)
>>> {measure (fun p=>(length (fst p))+(length (snd p)))} : list Z :=
>>> match p with
>>> | (nil,l) => l
>>> | (l,nil) => l
>>> | (x::xs,y::ys) => if Z_lt_ge_dec x y
>>> then x::(merge2 (xs,y::ys))
>>> else y::(merge2 (x::xs,ys))
>>> end.
>>> intros.
>>> simpl; auto with arith.
>>> intros.
>>> Qed.
>>> and now we are interested in computing
>>> Eval compute in merge2 ((1::3::5::nil),(2::4::6::nil)).
>>> In this case, the result that I obtain is
>>> let (v, _) :=
>>> merge2_terminate
>>> (1 :: 3 :: 5 :: Datatypes.nil, 2 :: 4 :: 6 :: Datatypes.nil)
>>> in
>>> v
>>> : list Z
>>> when I was expecting (1::2::3::4::5::6::nil).
>>> So, is it impossible to compute with a recursive function defined using
>>> Function?
>>> Thank you in advance.
- [Coq-Club] Executability of Function Command, jonathan . heras
- Re: [Coq-Club] Executability of Function Command,
Vincent Siles
Jónathan Heras
- Re: [Coq-Club] Executability of Function Command, Pierre Courtieu
Jónathan Heras
Vincent Siles
