- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Decidable equality on PositiveSets
- Date: Wed, 21 Dec 2011 11:01:38 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Message-ID:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=SY0cGzHWIkNywXzCmagjx16DJ6b2Lok0rv+uDLcL1Zy2XkAX+aF9ULXqH/kL4Y0PLwMWs4gvxx3lRJSeOvh5YIlGls96Sq43U1dqvh8Tk3Cg7F5MdLKu11tcDSHQUiW20EiduzBOXT99zyeO/gF/EP59vkjU6WxoZQnN+30Gr70=;
Thank you very much, it works. When reading the error message, I thought it
was just stating something impossible to be done (or that required extra
assumptions, such as proof irrelevance).
(and sorry about the name confusion, it should be better now)
--- En date de : Mer 21.12.11, Pierre Courtieu
<Pierre.Courtieu AT cnam.fr>
a écrit :
> De: Pierre Courtieu
>Â <Pierre.Courtieu AT cnam.fr>
> Objet: Re: [Coq-Club] Decidable equality on PositiveSets
> À: "Coq Dev"
>Â <coqletsgo AT yahoo.com>
> Cc:
>Â coq-club AT inria.fr
> Date: Mercredi 21 décembre 2011, 10h34
> This is due to the presence of "Local
> Unset Elimination Schemes" in
> MSetPositive.v. which means that elimination schemes are
> not generated
> automatically when tree is defined. Someone will probably
> tell us the
> reason for this. In the same file later there is an
> explicit:
> Scheme tree_ind := Induction for tree Sort Prop.
> Which builds one for sort Prop. You can build the same for
> sort Set in
> you own file:
> Scheme tree_rec := Induction for PositiveSet.tree Sort
> Set.
> Then your induction will work.
> P.
> PS Your name "Coq Dev" is confusing, as it is the name of a
> mailing
> list. Please consider changing it.
> 2011/12/21 Coq Dev
>Â <coqletsgo AT yahoo.com>:
> > Lemma l: forall (p p' : PositiveSet.t), {p = p'} + {p
> <> p'}.
> > Proof.
> > induction p.
- [Coq-Club] Decidable equality on PositiveSets, Coq Dev
- Re: [Coq-Club] Decidable equality on PositiveSets,
Pierre Courtieu
- Re: [Coq-Club] Decidable equality on PositiveSets, Coq Dev
- Re: [Coq-Club] Decidable equality on PositiveSets, AUGER Cédric
- Message not available
Damien Pous
Charles D
Charles D
Damien Pous
Pierre Courtieu
