- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Decidable equality on PositiveSets
- Date: Thu, 22 Dec 2011 12:25:02 +0100
Hi,
Yes and no :
- the remove function normalizes trees, so that in practice, the only
empty tree should be "Leaf" ;
- we did not need extensional equality to coincide with Leibniz
equality, so that we did not enforce this constraint.
This means that :
- you won't be able to prove that the two equalities coincide (they
don't, although they do on all objects you create through the
FSetInterface) ;
- the [equal] and [is_empty] functions have to handle the case where
they are given ill-formed trees (although the corresponding code will
never be executed in practice).
Enforcing the invariant and staying within the FSetInterface bounds
would require sig-types (like for, e.g., FSetList, FSetAVL...), which
introduce an overhead when using the data-structure for reflection
(vm_compute).
Damien
When we wrote this code
2011/12/21 AUGER Cédric
<Cedric.Auger AT lri.fr>:
> Le Wed, 21 Dec 2011 09:43:15 +0000 (GMT),
> Coq Dev
>Â <coqletsgo AT yahoo.com>
> a écrit :
>> Could someone please indicate me some texts (perhaps some basic ones)
>> that could help explain the following behavior?
>> Import MSetPositive.
>> Lemma l: forall (p p' : PositiveSet.t), {p = p'} + {p <> p'}.
>> Proof.
>> induction p.
>> Error: Cannot find the elimination combinator tree_rec, the
>> elimination of the inductive definition PositiveSet.tree on sort Set
>> is probably not allowed.
> By the way, I haven't read what the PositiveSet.t implementation is,
> but know that it may not be what you expect, that is you may have two
> sets wich are extensionnaly equal, but not intensionnaly.
> It is the case for the implementation of PositiveMap AFAIK:
> it is implemented with PATRICIA trees; but the implementation doesn't
> give unique representations; for example:
> empty:= (Node None None None)
> add 1 tt empty := (Node None (Node None None (Some tt)) None)
> remove (add 1 tt empty) 1 := (Node None (Node None None None) None),
> that is the result is not necessarily normalized, and even if it were,
> you have no information in general when you have a set if it is or not
> normalized.
> I already wrote a version with some tricks to have unicity of
> representations using a variation of the same structure;
> so I had a theorem, that if equality is decidable for elements, then
> equality is decidable for maps.
- [Coq-Club] Decidable equality on PositiveSets, Coq Dev
- Re: [Coq-Club] Decidable equality on PositiveSets, Pierre Courtieu
- Re: [Coq-Club] Decidable equality on PositiveSets, AUGER Cédric
- Message not available
- Re: [Coq-Club] Decidable equality on PositiveSets, Damien Pous
Charles D
Charles D
