- To: Beta Ziliani <beta AT mpi-sws.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] ML top level not working for me
- Date: Wed, 28 Dec 2011 12:00:55 +0100
Hi Beta,
> I'm having problems with the ML top level: I cannot do anything useful
> (not even go back to Coq).
> I've set the COQTOP variable pointing to the source files (i.e. the
> root Coq directory), and I'm running coqtop.byte. This is the output
> after Dropping:
> Coq < Drop.
> Objective Caml version 3.11.2
> Camlp5 Parsing version 5.14
> but if I want to go back to Coq, this is what happens:
> # go();;
> Error: Unbound value go
> It seems like it's not loading any Coq source but I don't see what I'm
> doing wrong. Any ideas? I'm using Coq trunk version:
> The Coq Proof Assistant, version trunk (December 2011)
> compiled on Dec 15 2011 18:28:45 with OCaml 3.11.2
Function "go()" is provided in the file "include" from the directory
dev of the source archive. So you'd better do that first
#use"include";;
Alternatively, you can have this be done automatically by adding a
file .ocamlinit in your home directory with the following content
(trick shown to me by Pierre Letouzey):
if Filename.basename Sys.argv.(0) = "coqtop.byte"
then ignore (Toploop.use_silently Format.std_formatter "include")
See file dev/doc/debugging.txt from the source archive for more
information on using the ocaml toplevel.
Hugo
- [Coq-Club] ML top level not working for me, Beta Ziliani
- Re: [Coq-Club] ML top level not working for me, Hugo Herbelin
Beta Ziliani
Jérémie Koenig
Beta Ziliani
Beta Ziliani
- Re: [Coq-Club] ML top level not working for me, Beta Ziliani
Beta Ziliani
Beta Ziliani
Jérémie Koenig
Beta Ziliani
Stéphane Glondu
