- To: Beta Ziliani <beta AT mpi-sws.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] ML top level not working for me
- Date: Fri, 30 Dec 2011 13:36:08 +0100
- Openpgp: id=49881AD3
Le 28/12/2011 10:27, Beta Ziliani a écrit :
> I'm having problems with the ML top level: I cannot do anything useful
> (not even go back to Coq).
> # go();;
> Error: Unbound value go
> It seems like it's not loading any Coq source but I don't see what I'm
> doing wrong. [...]
You have to issue "#directory" directives first:
#directory "/usr/lib/coq/interp";;
#directory "/usr/lib/coq/kernel";;
#directory "/usr/lib/coq/lib";;
#directory "/usr/lib/coq/library";;
etc.
one for each directory containing the .cmi file of a module you want to
access (adapt /usr/lib/coq/ accordingly). With zsh, you can generate a
"directories" file with the following command:
for u in $COQROOT/**/*.cmi; do echo '#directory "'"${u%/*}"'";;'; done |
sort -u > directories
Then, you can run '#use "directories";;' before running commands from
e.g. dev/include.
It seems that #directory are implicit for each "-I" given when linking
coqtop.byte, which may explain why you don't have to run them when the
source tree is still there.
Cheers,
Stéphane
- [Coq-Club] ML top level not working for me, Beta Ziliani
- Re: [Coq-Club] ML top level not working for me,
Hugo Herbelin
Beta Ziliani
Jérémie Koenig
Beta Ziliani
Beta Ziliani
- Re: [Coq-Club] ML top level not working for me, Beta Ziliani
Beta Ziliani
Beta Ziliani
Jérémie Koenig
Beta Ziliani
- Re: [Coq-Club] ML top level not working for me, Stéphane Glondu
Hugo Herbelin
