coq-club - Re: [Coq-Club] ML top level not working for me
chronological Thread
  • To: Beta Ziliani <beta AT mpi-sws.org>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] ML top level not working for me
  • Date: Wed, 28 Dec 2011 12:11:16 +0100
On Wed, Dec 28, 2011 at 12:00 PM, Hugo Herbelin
<Hugo.Herbelin AT inria.fr>
 wrote:
> Hi Beta,
> Function "go()" is provided in the file "include" from the directory
> dev of the source archive. So you'd better do that first
>  #use"include";;
> Alternatively, you can have this be done automatically by adding a
> file .ocamlinit in your home directory with the following content
> (trick shown to me by Pierre Letouzey):
>  if Filename.basename Sys.argv.(0) = "coqtop.byte"
>  then ignore (Toploop.use_silently Format.std_formatter "include")
> See file dev/doc/debugging.txt from the source archive for more
> information on using the ocaml toplevel.
> Hugo
Thanks Hugo, but I forgot to mention something important:
# #use "include";;
Cannot find file include.
It's like if it's not taking COQTOP into account, although it is well set:
$ ls $COQTOP
CHANGES        CREDITS      INSTALL.ide     Makefile         ...
