- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] No more info tactical?!
- Date: Fri, 06 Jan 2012 08:36:41 -0500
Arnaud Spiwack wrote:
As a devoted Adamizer of proof scripts (with a summer's worth of
Ltackery to prove it), I can't imagine life without info ...
I'd be interested in knowing how you use it.
The usual scenario is that some complex Ltac program isn't behaving as expected, so you run that tactic with [info], which outputs the sequence of steps taken "at one level lower in the abstraction stack." Then you run each of these tactics, until one behaves unexpectedly. Now run that tactic with [info] and repeat. This can really be a lifesaver in Ltac debugging. I don't know if some new 8.4 facility compensates. (I try to stick to the Debian testing packages only, so I've only yet experienced behaviors up to 8.3.)
- [Coq-Club] No more info tactical?!, Luke Maurer
- Re: [Coq-Club] No more info tactical?!,
Arnaud Spiwack
- Re: [Coq-Club] No more info tactical?!, Adam Chlipala
Pierre Courtieu
Adam Chlipala
Pierre Courtieu
Adam Chlipala
- Re: [Coq-Club] No more info tactical?!, Luke Maurer
- Re: [Coq-Club] No more info tactical?!, Paul Broome
- Re: [Coq-Club] No more info tactical?!, Arnaud Spiwack
Adam Chlipala
Pierre Courtieu
Adam Chlipala
Pierre Courtieu
- Re: [Coq-Club] No more info tactical?!, Jonas B. Jensen
Arnaud Spiwack
