coq-club - Re: [Coq-Club] No more info tactical?!
chronological Thread
  • To: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] No more info tactical?!
  • Date: Fri, 06 Jan 2012 11:41:27 -0500
OK, I've found that mechanism to be almost impossible to use for most debugging tasks. [info] has been much more useful. The problem with the tactic debugger is that it has an odd notion of the granularity of steps, with no way to skip steps beside counting them, rather than saying something like "run until we are done evaluating tactic [foo]". (Or maybe I'm just not familiar with its capabilities.) This is especially bad when debugging a tactic that calls [intuition], which generates many steps that the debugger chooses to show when stepping!
Pierre Courtieu wrote:
It is the same command.
P.
2012/1/6 Adam Chlipala
<adamc AT csail.mit.edu>:
For this use there is a debug mechanism for Ltac. It has been there
for a while but is now shortly documented
(http://coq.inria.fr/coq/refman/Reference-Manual012.html#@default763).
Set Ltac Debug.
Is this different from [Debug On]?
