- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq_makefile including subdirectories
- Date: Wed, 22 Feb 2012 18:21:14 +0900
- Authentication-results: mr.google.com; spf=pass (google.com: domain of leegys AT gmail.com designates 10.68.218.228 as permitted sender) smtp.mail=leegys AT gmail.com; dkim=pass header.i=leegys AT gmail.com
Many thanks for the reply.
Let me make my question more concrete.
Assume in a directory called foo I have the coq files A1.v, A2.v.
And there is a subdirectory called foo_sub where B1.v, B2.v B3.v are contained.
Furthermore, A1.v and A2.v depend on files B1.v, B2.v, and B3.v.
My question was: how to create Makefile using coq_makefile such that I just need to type "make" to compie A1.v and A2.v?
(that is all the files in the foo directory)
If there is no dependency involving subdirectories or other directories, I used to do the following:
coq_makefile *.v > Makefile
and just type "make" to compile all the files.
I hope my question is this time clearer.
Gyesik
2012/2/22 Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
Hi,
I do not understand what you want.
Is it
I've got A.v, foo/B.v, foo/C.v where A Requires Foo.B and B Requires Foo.C.
I write
-R . toto
A.v
in my _CoqProject file. I do coq_makefile -f _CoqProject -o Makefile
and I expect everything to work ?
This will not because of dependencies; only the one of listed files are compute so you will have
A.vo: foo/B.vo
but nothing that say
foo/B.vo: foo/C.vo
and C will no be compiled.
I may complitely miss the point and, because I need to rewrite coq_makefile documentation, I'm interressted to get more information.
All the best,
Pierre Boutillier
Le 22 févr. 12 à 04:22, Gyesik Lee a écrit :
Hi,
would someone remind me of how to create Makefile such that all the dependent files in subdirectories or special directories can be automatically involved during compilation?
I tried to follow the instructions from the coq_makefile --help, but failed.
Any help would be appreciated.
Gyesik
- [Coq-Club] coq_makefile including subdirectories, Gyesik Lee
- Re: [Coq-Club] coq_makefile including subdirectories,
Pierre Boutillier
- Re: [Coq-Club] coq_makefile including subdirectories, Gyesik Lee
Gyesik Lee
- Re: [Coq-Club] coq_makefile including subdirectories, Pierre Boutillier
- Re: [Coq-Club] coq_makefile including subdirectories, Jelle Herold
Pierre Boutillier
