coq-club - Re: [Coq-Club] coq_makefile including subdirectories
chronological Thread
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: Gyesik Lee <leegys AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coq_makefile including subdirectories
  • Date: Wed, 22 Feb 2012 10:48:48 +0100
In very durty :
coq_makefile $(find . -type d -exec echo -I \{\} \;) $(find -name \*.v -print) -o Makefile
In less durty :
coq_makefile -R . SuperLib $(find -name \*.v -print) -o Makefile
(but then you'll have to Require Foo_sub.B? in A? files)
and
{ echo ’-R . MyFancyLib ’ ; find -name ’*.v’ -print } > _CoqProject && coq_makefile -f _CoqProject -o Makefile
In the last case
 - coq_makefile will be automatticaly called if something change in the _CoqProject file (you add a file or an option)
 - if you use coqide, you can set up it up in order that it does automaticaly the -R . MyFancyLib when you open one of the file listed in the _Coq_project file ...
Pierre
Le 22 févr. 12 à 10:21, Gyesik Lee a écrit :
Many thanks for the reply.
Let me make my question more concrete.
Assume in a directory called foo I have the coq files A1.v, A2.v.
And there is a subdirectory called foo_sub where B1.v, B2.v B3.v are contained.
Furthermore, A1.v and A2.v depend on files B1.v, B2.v, and B3.v.
My question was: how to create Makefile using coq_makefile such that I just need to type "make" to compie A1.v and A2.v?
(that is all the files in the foo directory)
If there is no dependency involving subdirectories or other directories, I used to do the following:
coq_makefile *.v > Makefile
and just type "make" to compile all the files.
I hope my question is this time clearer.
Gyesik
2012/2/22 Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
Hi,
I do not understand what you want.
Is it
I've got A.v, foo/B.v, foo/C.v where A Requires Foo.B and B Requires Foo.C.
I write
-R . toto
A.v
in my _CoqProject file. I do coq_makefile -f _CoqProject -o Makefile
and I expect everything to work ?
This will not because of dependencies; only the one of listed files are compute so you will have
A.vo: foo/B.vo
but nothing that say
foo/B.vo: foo/C.vo
and C will no be compiled.
I may complitely miss the point and, because I need to rewrite coq_makefile documentation, I'm interressted to get more information.
All the best,
Pierre Boutillier
Le 22 févr. 12 à 04:22, Gyesik Lee a écrit :
Hi,
would someone remind me of how to create Makefile such that all the dependent files in subdirectories or special directories can be automatically involved during compilation?
I tried to follow the instructions from the coq_makefile --help, but failed.
Any help would be appreciated.
Gyesik
