- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq_makefile including subdirectories
- Date: Wed, 22 Feb 2012 22:10:42 +0900
- Authentication-results: mr.google.com; spf=pass (google.com: domain of leegys AT gmail.com designates 10.68.74.74 as permitted sender) smtp.mail=leegys AT gmail.com; dkim=pass header.i=leegys AT gmail.com
Dear Pierre,
thank you for your help.
(I am using Emacs with proofgeneral in linux or os x environment.)
I didn't know that in the reference of V8.4beta a more detailed explanation about coq_makefile is made than before.
Anyway, both manual versions works great.
But I don't understand how to use the following really "FANCY" style which is also explained in the reference.
{ echo ’-R . MyFancyLib ’ ; find -name ’*.v’ -print } > _CoqProject && coq_makefile -f _CoqProject -o Makefile
Please excuse my ignorance, but when I just did copy-and-paste that line into the Terminal, then I was prompted by "<" symbol expecting some inputs.
I don't know what to do then.
Would you give more explanation?
Gyesik
In the last case- coq_makefile will be automatticaly called if something change in the _CoqProject file (you add a file or an option)- if you use coqide, you can set up it up in order that it does automaticaly the -R . MyFancyLib when you open one of the file listed in the _Coq_project file ...PierreLe 22 févr. 12 à 10:21, Gyesik Lee a écrit :Many thanks for the reply.Let me make my question more concrete.Assume in a directory called foo I have the coq files A1.v, A2.v.And there is a subdirectory called foo_sub where B1.v, B2.v B3.v are contained.Furthermore, A1.v and A2.v depend on files B1.v, B2.v, and B3.v.My question was: how to create Makefile using coq_makefile such that I just need to type "make" to compie A1.v and A2.v?(that is all the files in the foo directory)
If there is no dependency involving subdirectories or other directories, I used to do the following:coq_makefile *.v > Makefileand just type "make" to compile all the files.I hope my question is this time clearer.Gyesik2012/2/22 Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
Hi,
I do not understand what you want.
Is it
I've got A.v, foo/B.v, foo/C.v where A Requires Foo.B and B Requires Foo.C.
I write
-R . toto
A.v
in my _CoqProject file. I do coq_makefile -f _CoqProject -o Makefile
and I expect everything to work ?
This will not because of dependencies; only the one of listed files are compute so you will have
A.vo: foo/B.vo
but nothing that say
foo/B.vo: foo/C.vo
and C will no be compiled.
I may complitely miss the point and, because I need to rewrite coq_makefile documentation, I'm interressted to get more information.
All the best,
Pierre Boutillier
Le 22 févr. 12 à 04:22, Gyesik Lee a écrit :
Hi,
would someone remind me of how to create Makefile such that all the dependent files in subdirectories or special directories can be automatically involved during compilation?
I tried to follow the instructions from the coq_makefile --help, but failed.
Any help would be appreciated.
Gyesik
- [Coq-Club] coq_makefile including subdirectories, Gyesik Lee
- Re: [Coq-Club] coq_makefile including subdirectories,
Pierre Boutillier
- Re: [Coq-Club] coq_makefile including subdirectories, Gyesik Lee
Gyesik Lee
Pierre Boutillier
Pierre Boutillier
- Re: [Coq-Club] coq_makefile including subdirectories, Jelle Herold
Pierre Boutillier
