coq-club - Re: [Coq-Club] Question on Opaque/Transparent... or: one step of reduction of a fixpoint
chronological Thread
  • To: Stéphane Glondu <steph AT glondu.net>
  • Cc: Francois Pottier <Francois.Pottier AT inria.fr>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Question on Opaque/Transparent... or: one step of reduction of a fixpoint
  • Date: Mon, 27 Feb 2012 19:30:11 +0100
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of sedrikov AT gmail.com designates 10.180.78.233 as permitted sender) smtp.mail=sedrikov AT gmail.com; dkim=pass header.i=sedrikov AT gmail.com
Le Mon, 27 Feb 2012 18:12:17 +0100,
Stéphane Glondu
 a Ã©crit :
> Le 27/02/2012 13:53, Francois Pottier a Ã©crit :
> > What I would like to do at this point is perform one step of
> > reduction, that is, reduce the application of f to (C x) by
> > appealing to the definition of f as a Fixpoint.
> Not exactly what you're asking for, but what about "unfold f; fold f"?
> Cheers,
If it is some very precise place, you can also consider
"change f with (C x) [in â€¦] [at â€¦]."
The "fold" is often not what I want (I have to give the parameters of
"f", like in "fold (f x)." to do what I want), but in case of
fixpoint, Stéphane suggestion should work if there is no
automatic reduction inside the fixpoint definition (which hopefully
shouldn't occur).
