- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] dependent induction 2
- Date: Mon, 27 Feb 2012 19:08:28 +0100
On 2012-02-27 09:44, Arnaud Spiwack wrote:
My feverish brain does not manage to see under which precise
assumption this holds. However, I doubt it'll work for Coq (I'm
guessing the fact that the type argument is taken in a predicative
sort rather than an impredicative one would be the issue).
It is easy to prove that the two types are isomorphic:
Set Implicit Arguments.
Inductive Eq1 (A : Type) (x : A) : A -> Prop :=
refl1 : Eq1 x x.
Inductive Eq2 (A : Type) : A -> A -> Prop :=
refl2 (x : A) : Eq2 x x.
Record Iso (A B : Prop) : Prop :=
{ to : A -> B
; from : B -> A
; to_from : forall x, to (from x) = x
; from_to : forall x, from (to x) = x
Lemma Eq1_to_Eq2 (A : Type) (x y : A) (eq : Eq1 x y) : Eq2 x y.
Proof.
intros.
destruct eq.
exact (refl2 _).
Defined.
Lemma Eq2_to_Eq1 (A : Type) (x y : A) (eq : Eq2 x y) : Eq1 x y.
Proof.
intros.
destruct eq.
exact (refl1 _).
Defined.
Lemma isomorphic (A : Type) (x y : A) : Iso (Eq1 x y) (Eq2 x y).
Proof.
intros.
refine (Build_Iso (fun eq => Eq1_to_Eq2 eq)
(fun eq => Eq2_to_Eq1 eq) _ _).
intros eq.
destruct eq.
exact (eq_refl _).
intros eq.
destruct eq.
exact (eq_refl _).
Defined.
Given the isomorphism it is straightforward to define Paulin-Mohring's
variant of J (eliminating into Type) for both types:
Lemma J1 (A : Type) (x : A)
(P : forall y, Eq1 x y -> Type)
(p : P x (refl1 x))
(y : A) (eq : Eq1 x y) : P y eq.
Proof.
intros.
destruct eq.
exact p.
Defined.
Lemma J2 (A : Type) (x : A)
(P : forall y, Eq2 x y -> Type)
(p : P x (refl2 x))
(y : A) (eq : Eq2 x y) : P y eq.
Proof.
intros.
set (P' := fun y => fun eq => P y (Eq1_to_Eq2 eq)).
set (p' := J1 P' p (Eq2_to_Eq1 eq)).
unfold P' in p'.
set (lemma := to_from (isomorphic x y) eq).
unfold isomorphic, to, from in lemma.
rewrite lemma in p'.
exact p'.
Defined.
/NAD
- [Coq-Club] dependent induction 2, Andrew Polonsky
- Re: [Coq-Club] dependent induction 2,
Arnaud Spiwack
Nils Anders Danielsson
Arnaud Spiwack
- Re: [Coq-Club] dependent induction 2, Nils Anders Danielsson
- Re: [Coq-Club] dependent induction 2, Arnaud Spiwack
Arnaud Spiwack
Pierre Courtieu
Adam Chlipala
- Re: [Coq-Club] dependent induction 2, Pierre Courtieu
Vincent Siles
- Re: [Coq-Club] dependent induction 2, Andrew Polonsky
Adam Chlipala
Arnaud Spiwack
