coq-club - Re: [Coq-Club] The function over the same function without induction
chronological Thread
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] The function over the same function without induction
  • Date: Sat, 03 Mar 2012 11:04:05 -0500
Marko Malikoviæ wrote:
Parameter State : Set.
Parameter X Y Z W : State ->  nat.
Definition FourTuple (S : State) := (X S, Y S, Z S, W S).
Function that change (and rotate) the elements of the tuple is (for example):
Definition Change1 (S : State) := (Y S + 1, X S + 2, W S + 3, Z S + 4).
And now I have no idea how to define function Change2 which have to be
Change1 of Change1. The reason is clear: Change1 takes an argument of type
State, and returns the result of type tuple.
Are you just asking how to write a tuple type in Coq? If so, that should certainly be covered in any standard introduction to Coq.
