- To: Marko Malikovi� <marko AT ffri.hr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] The function over the same function without induction
- Date: Sat, 03 Mar 2012 11:54:51 -0500
Marko Malikoviæ wrote:
No,
I ask whether it is possible to create a function Change2 that will be
defined as "Change1 (Change1 SomeTuple)" but without the use of induction.
So, the function which will two (or more) times in the same way change the
tuple. So Change1 function must return a result that is the same type as
its argument.
Something like this:
Definition Change2 (TupleB): = Change1 (Change1 TupleA).
I'm still having trouble identifying some non-trivial issue in your question. Are you asking how to write a recursive function in Coq? Or when you write "induction" do you mean "recursion," such that you are looking for a way to implement an iterated self-composition function without explicit recursion?
- [Coq-Club] The function over the same function without induction, Marko Malikoviæ
- Re: [Coq-Club] The function over the same function without induction,
Adam Chlipala
- Re: [Coq-Club] The function over the same function without induction, Marko Malikoviæ
Marko Malikoviæ
- Re: [Coq-Club] The function over the same function without induction, Adam Chlipala
- Re: [Coq-Club] The function over the same function without induction, Jonas Oberhauser
Adam Chlipala
