coq-club - Re: [Coq-Club] The function over the same function without induction
chronological Thread
  • To: Marko Maliković <marko AT ffri.hr>
  • Cc: s9joober AT googlemail.com, adamc AT csail.mit.edu, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] The function over the same function without induction
  • Date: Mon, 5 Mar 2012 09:42:45 +0100
Le Sat, 3 Mar 2012 19:39:07 +0100 (CET),
Marko Maliković
<marko AT ffri.hr>
 a Ã©crit :
> It is no longer important. I just forgot about the composition of
> functions. Thanx to Jonas Oberhauser. He understood what I need.
I guess that what was proposed was to have a function from states to
tuples:
Definition tupleOfState (S : State) := (X S, Y S, Z S, T S).
And then have regular functions on tuples:
Definition change1 (t : nat*nat*nat*nat) : nat*nat*nat*nat :=
 let (a,b,c,d) := t in (a+1,b+2,c+3,d+4).
So that you could define:
Definition Change1 s := change1 (tupleOfState s).
Definition Change2 s := change1 (change1 (tupleOfState s)).
Am I wrong?
> Greetings,
> Marko Malikovic
> > Marko Maliković wrote:
> >> No,
> >> I ask whether it is possible to create a function Change2 that
> >> will be defined as "Change1 (Change1 SomeTuple)" but without the
> >> use of induction.
> >> So, the function which will two (or more) times in the same way
> >> change the
> >> tuple. So Change1 function must return a result that is the same
> >> type as its argument.
> >> Something like this:
> >> Definition Change2 (TupleB): = Change1 (Change1 TupleA).
> > I'm still having trouble identifying some non-trivial issue in your
> > question.  Are you asking how to write a recursive function in
> > Coq?  Or when you write "induction" do you mean "recursion," such
> > that you are looking for a way to implement an iterated
> > self-composition function without explicit recursion?
