coq-club - Re: [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath
chronological Thread
  • To: Jelle Herold <jelle AT defekt.nl>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath
  • Date: Tue, 3 Apr 2012 17:45:41 +0200
Hello,
2012/4/3 David MENTRE
<dmentre AT linux-france.org>:
> 2012/4/3 Jelle Herold
> <jelle AT defekt.nl>:
>> I'm not entirely shure what the problem is, these are rather old versions
>> of
>> PG and coq
As a follow-up: as suggested by Jelle and also privately, I have
manually installed a more recent ProofGeneral 4.1. Using following
lines in my .emacs, it works like a charm:
;; For PG 4.1
(load-file "/home/david/install/ProofGeneral/generic/proof-site.el")
(setq coq-load-path '(("/usr/local/lib/why3/coq/real" "Why3.real")
                      ("/usr/local/lib/why3/coq/int" "Why3.int")))
Many thanks!
Best regards,
d.
