- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath
- Date: Tue, 3 Apr 2012 14:16:18 +0200
Hello,
I have an issue to setup a working ProofGeneral environment with Coq.
Versions used:
* The Coq Proof Assistant, version 8.3pl2 (August 2011)
* ProofGeneral 3.7
* GNU Emacs 23.3.1
* System: Ubuntu Linux 11.10 (oneiric)
All are coming from Ubuntu's packages.
I added following lines in my .emacs:
;; For ProofGeneral mode
(setq coq-version-is-V8-0 nil)
(setq coq-version-is-V8-1 t)
(setq coq-prog-name "coqtop")
(setq coq-load-path '("/usr/local/lib/why3/coq"
"/usr/local/lib/why3/coq/int"
"/usr/local/lib/why3/coq/real"))
[ Side note: I need to configure "coq-version-is-V8-1" and
"coq-prog-name" variables for ProofGeneral to work. ]
The /usr/local/lib/why3/coq/real/ directory contains needed Coq .vo files:
$ ls /usr/local/lib/why3/coq/real/
Abs.vo ExpLog.vo FromInt.vo MinMax.vo Real.vo Square.vo
I am testing this configuration on following demo.v file:
Require Import ZArith.
Require Import Rbase.
Require real.Real.
To test it:
1. I start Emacs
2. I load ProofGeneral with M-x proofgeneral (apparently a Debian
specific configuration)
3. I open the .v file (ProofGeneral correctly starts)
4. I load in Coq each file line with C-c C-n
The "Require real.Real" line fails (after a C-c C-n) with "Error:
Cannot find library real.Real in loadpath" error message.
I googled the web, read the manual, read Debian
/usr/share/doc/proofgeneral/ but I now really don't understand why my
"coq-load-path" is not taken into account.
Any hint?
Sincerely yours,
david
- [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath, David MENTRE
