- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Rewriting with "identity type in Type"
- Date: Wed, 4 Apr 2012 10:00:33 +0200
> actually in 8.3pl2 rewrite works with "identity" - a version of paths which
> is defined in Coq.Init. It does not work with "paths" defined separately,
> but if you define "paths" (as I do in the latest version of my library) as
> a notation for "idenity" then rewrite works with it.
Yes, I noticed that. It actually works with any type that is defined
just like identity, i.e., you could define your own paths as
Inductive paths {A : Type} (x : A) : A -> Type := idpath : paths x x.
and it would still work exactly the same. It's really nice to have
rewriting for homotopy type theory.
With kind regards,
Andrej
- [Coq-Club] Rewriting with "identity type in Type", Andrej Bauer
- [Coq-Club] Re: Rewriting with "identity type in Type",
Andrej Bauer
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Jean-Francois Monin
Vladimir Voevodsky
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Andrej Bauer
Andrej Bauer
