coq-club - Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation
chronological Thread
  • To: Valentin Robert <valentin.robert.42 AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation
  • Date: Mon, 23 Apr 2012 09:22:18 -0400
On 04/23/2012 09:09 AM, Valentin Robert wrote:
The following snippet exposes some behaviors of Ltac's binding/matching that I
fail to understand (or to find details about in the manual). I wonder whether
it is a bug, a known problem, or possibly an expected behavior.
My goal is to pass two arguments to the tactic to guide it towards which
hypotheses it should use. Using Ltac, things do not work quite as I expect
them
to.
Can you explain how the behavior is different from what you expect?
Using:
Tactic Notation "my_tactic" constr(rs) constr(r)
seems to solve this particular issue, but can I make such a tactic notation
recursive?
Or can I use constr(...) somehow in Ltac?
Or do I need to mix Ltac and Tactic Notation to get the best of both worlds?
Any advice on dealing with such issues would be greatly appreciated.
- Valentin Robert
(* Beginning Coq snippet.
I have not tested it on trunk, the results shown here are for Coq 8.3pl4.
Ltac match_args_A rs r :=
   match goal with H: rs = r |- _ =>
     let H' := fresh "H" in rename H into H'
   end.
Ltac match_args_B rs r :=
     let r' := fresh "r" in rename r into r'
   end.
Theorem test_0: 0 = 1 ->  True.
Proof.
   intros.
   match_args_A 0 1. (*works*)
(*match_args_B 0 1. No matching clauses for match goal*)
(*match_args_A 1 2. No matching clauses for match goal*)
(*match_args_B 1 2. No matching clauses for match goal*)
(*match_args_A foo bar. No matching clauses for match goal*)
(*match_args_B foo bar. No matching clauses for match goal*)
   exact I.
Qed.
Theorem test_1: forall (rs: nat) r, rs = r ->  True.
Proof.
   intros.
(*match_args_A 0 1. No matching clauses for match goal*)
   match_args_A rs r. (*works*)
   match_args_B rs r. (*works*)
   rename r0 into r.
   match_args_A foo bar. (*works!*)
   exact I.
Qed.
