Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation
chronological Thread
- From: Valentin ROBERT <valentin.robert.42 AT gmail.com>
- To: Stéphane Glondu <steph AT glondu.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation
- Date: Tue, 24 Apr 2012 11:18:57 +0200
Thanks, the solution combining Ltac and Tactic Notation solves my issue.
Best regards,
- Valentin Robert
On Mon, Apr 23, 2012 at 16:35, Stéphane Glondu
wrote:
> Le 23/04/2012 16:08, Valentin ROBERT a écrit :
>> So I should rephrase my thought into: it seemed to do what I expected
>> sometimes (that is, work quite like if I had used a tactic notation
>> with constr(...)), but it also did something I did not expect to
>> happen (that is, accept match_args_A foo bar where foo and bar don't
>> exist). Now, I do not understand why I can pass these parameters,
>> while the behavior does not seem to depend on what I pass in.
> I think foo and bar are here interpreted as raw identifiers. For
> example, you can do:
> Ltac intro2 x := intro x.
> Theorem test: forall (rs: nat) r, rs = r -> True.
> Proof.
> intro2 rs.
> The constr(...) in Tactic Notation forces ... to be a valid constr
> (hence, to exist).
> I suggest you expose your tactic to users as a Tactic Notation that
> forces constr(...). You can define recursively your tactic using Ltac,
> and force the type of the argument in recursive calls, as in:
> Ltac mytac_internal x :=
> mytac_internal (constr:...).
> Tactic Notation "mytac" constr(x) := mytac_internal x.
> Cheers,
> Stéphane
- [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation, Valentin Robert
- Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation,
Adam Chlipala
Valentin ROBERT
Stéphane Glondu
- Re: [Coq-Club] About binding and matching in Ltac, and recursive Tactic Notation, Valentin ROBERT
Stéphane Glondu
Valentin ROBERT
Adam Chlipala
