coq-club - Re: [Coq-Club] equality of equality of equality of equality
  • To: Andrej Bauer <andrej.bauer AT andrej.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] equality of equality of equality of equality
  • Date: Thu, 17 May 2012 05:44:25 +0200
Le Wed, 16 May 2012 16:12:16 +0200,
Andrej Bauer
a écrit :
> > Inductive endpoints (T : Type) : nat -> Type :=
> > | End : T -> endpoints T O
> > | Step : forall n (a b : endpoints T n), a = b -> endpoints T (S n).
> > I don't know if it is what you wish.
> > Typically, if you have something of type "endpoints T 2", you can
> > decompose it into:
> > a : T
> > b : T
> > c : T
> > d : T
> > Hab : End a = End b (* thus a = b *)
> > Hcd : End c = End d (* thus c = d *)
> > Habcd : Step Hab = Step Hcd
> Thanks. I would have to think a bit about this because we get the
> unwanted wrappers "Step (Step ... End a)...)". This may complicate
> matters a bit. For a perfect solution we'd also want a function which
> strips off the "End"s and "Steps" so that, for example, Hab above
> would have the type a = b and Habcd woudl have the type Hab = Hcd.
> But it is perhaps easier to use your definition and define an
> auxiliary function which performes the stripping as an afterthought.
> With kind regards,
> Andrej
Inductive endpoints (T : Type) (a b : T) : nat -> Type :=
| End : a = b -> endpoints T O
| Step : forall n (X Y : endpoints T a b n), X = Y ->
endpoints T a b (S n).
Is another version which avoids to have many T at the end.
But you still won't be able to unwrap it completely, as
you will have:
H1 : a = b
H2 : a = b
H3 : a = b
H4 : a = b
H5 : H1 = H2
H6 : H3 = H4
H7 : H5 = H6 ← type mismatch H1=H2 vs H3=H4
