- To: Andrej Bauer <andrej.bauer AT andrej.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] equality of equality of equality of equality
- Date: Thu, 17 May 2012 14:31:57 -0400
How about
Definition eqnplus1 ( n:nat ) {X : Type} ( x y : X) : Type.
Proof. here follow the "destruct n" with eq X x y for n=0 and the obvious
step for n+1. Defined.
V.
On May 15, 2012, at 5:28 PM, Andrej Bauer wrote:
> I am trying to formalize arguments in Coq which use arbitrarily nested
> identity types, i.e., I want to write things like:
> forall (x0 y0 : A) (x1 y1 : x0 = y0) (x2 y2 : x1 = y1) ... (xn yn :
> x(n-1) = y(n-1), ....
> What is the best way to organize things here? Typically, I need access
> to the highest-level term xn yn, and typically I need to show
> something for every level n of nesting.
> Some sort of magic involving Inductive or Fixpoint is called for. The
> above nested forall could be replaced, e.g., by something like
> forall (p q : eq' n), ...
> where eq' n is the n-th iterated identity type. But not quite. Help!
> With kind regards,
> Andrej
- [Coq-Club] equality of equality of equality of equality, Andrej Bauer, 05/15/2012
- Re: [Coq-Club] equality of equality of equality of equality, Adam Chlipala, 05/15/2012
- Re: [Coq-Club] equality of equality of equality of equality, Daniel Schepler, 05/16/2012
- Re: [Coq-Club] equality of equality of equality of equality, Favonia, 05/16/2012
- Re: [Coq-Club] equality of equality of equality of equality, Andrej Bauer, 05/16/2012
- Re: [Coq-Club] equality of equality of equality of equality, AUGER Cédric, 05/16/2012
- Re: [Coq-Club] equality of equality of equality of equality, AUGER Cédric, 05/17/2012
- Re: [Coq-Club] equality of equality of equality of equality, Vladimir Voevodsky, 05/17/2012
- Re: [Coq-Club] equality of equality of equality of equality, Andrej Bauer, 05/18/2012
- Re: [Coq-Club] equality of equality of equality of equality, Daniel Schepler, 05/19/2012
- Re: [Coq-Club] equality of equality of equality of equality, Daniel Schepler, 05/20/2012
