coq-club - Re: [Coq-Club] A smarter "induction;econstructor" combo?
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] A smarter "induction;econstructor" combo?
  • Date: Tue, 22 May 2012 20:53:58 +0200
Le Tue, 22 May 2012 17:36:58 +0200,
Paolo Herms
<paolo.herms AT cea.fr>
a écrit :
> On Tuesday 22 May 2012 15:19:10 Francois Pottier wrote:
> > > econstuctor (solve [eauto]).
> > > I don't think it's documented; I've found it by idly reading the
> > > Coq source
> > > code.
> Of course, this is documented as part of the tactic language
> http://coq.inria.fr/refman/Reference-Manual012.html
Well, that is ok if your goal is easily solvable.
But when you have something like:
Inductive X : nat → Prop :=
| XO : hard_to_prove_1 → X O
| XS1 : ∀ n, impossible_to_prove n → X (S n)
| XS2 : ∀ n, hard_to_prove_2 n → X (S n)
Then if you want to prove "∀ n, X n",
you start doing "induction n."
then:
"constructor. ..."
"constructor 3. ..."
But in this case, you may wish to have a
"induction n; try constructor only_possible_one." tactic which will
perform constructor 1 for the first case, but won't do anything in the
second case, since there are two choices.
Such a tactic could be done in Ocaml, it would count all the cases
where "constructor <n>" succeds and check that only one case is ok.
If many solutions are found, nothing is done and if none, a failure
should be returned.
The interest of such a tactic is to be a non-blocking one; that is
using it won't lead you to a place where you are stuck even if you
weren't in the first place.
