- To: bartdevylder AT gmail.com
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] double "apply" not solved with auto
- Date: Mon, 11 Jun 2012 10:38:47 -0400
[auto] works by syntactic matching of head symbols, and the conclusion and [H] don't start with the same head symbol. You should be able to use a [Hint Extern] to get the effect you want, though.
On 06/11/2012 10:35 AM,
wrote:
I am puzzled why the auto tactic does not solve a subgoal which only involves
applying "apply" twice with a Hypothesis from the current context. I didn't
find a solution/explanation in the documentation or mailing lists.
Concretely, this is the state I'm stuck in:
2 subgoals
s : state
v : volumeName
H : uniqueLocation s
H0 : consistent1 s
v1 : volumeName
v2 : volumeName
H1 : v1<> v2
______________________________________(1/2)
match s v1 with
| volstate n1 p1 _ _ =>
match s v2 with
| volstate n2 p2 _ _ => n1<> n2 \/ p1<> p2
end
end
- [Coq-Club] double "apply" not solved with auto, bartdevylder, 06/11/2012
- Re: [Coq-Club] double "apply" not solved with auto, Adam Chlipala, 06/11/2012
- Re: [Coq-Club] double "apply" not solved with auto, Bart De Vylder, 06/13/2012
- Re: [Coq-Club] double "apply" not solved with auto, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] double "apply" not solved with auto, Bart De Vylder, 06/14/2012
