coq-club - Re: [Coq-Club] double "apply" not solved with auto
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] double "apply" not solved with auto
  • Date: Thu, 14 Jun 2012 11:31:58 +0200
On Wed, Jun 13, 2012 at 7:44 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 06/13/2012 01:16 PM, Bart De Vylder wrote:
If I use Hint Extern to match against the goal somehow, I don't see how i can refer to 'some' hypothesis in the context.
I read in the docs that Hint Extern can also be used to match against a hypothesis in the context, but I can't find an example of the syntax to use.
You don't use some special [Hint Extern] support for matching hypotheses.  Rather, to the right of the [=>], you write normal Ltac code for hypothesis matching.
Ok, got it, thx.
Bart De Vylder
+32(0)496/558065
bartdevylder AT gmail.com
