- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] double "apply" not solved with auto
- Date: Wed, 13 Jun 2012 19:16:50 +0200
On Mon, Jun 11, 2012 at 4:38 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
[auto] works by syntactic matching of head symbols, and the conclusion and [H] don't start with the same head symbol. You should be able to use a [Hint Extern] to get the effect you want, though.
Thanks for your answer, but it seems I can't get it to work.
If I use Hint Extern to match against the goal somehow, I don't see how i can refer to 'some' hypothesis in the context.
I read in the docs that Hint Extern can also be used to match against a hypothesis in the context, but I can't find an example of the syntax to use.
On 06/11/2012 10:35 AM, bartdevylder AT gmail.com wrote:
I am puzzled why the auto tactic does not solve a subgoal which only involves
applying "apply" twice with a Hypothesis from the current context. I didn't
find a solution/explanation in the documentation or mailing lists.
Concretely, this is the state I'm stuck in:
2 subgoals
s : state
v : volumeName
H : uniqueLocation s
H0 : consistent1 s
v1 : volumeName
v2 : volumeName
H1 : v1<> v2
______________________________________(1/2)
match s v1 with
| volstate n1 p1 _ _ =>
match s v2 with
| volstate n2 p2 _ _ => n1<> n2 \/ p1<> p2
end
end
Bart De Vylder
+32(0)496/558065
- [Coq-Club] double "apply" not solved with auto, bartdevylder, 06/11/2012
- Re: [Coq-Club] double "apply" not solved with auto, Adam Chlipala, 06/11/2012
- Re: [Coq-Club] double "apply" not solved with auto, Bart De Vylder, 06/13/2012
- Re: [Coq-Club] double "apply" not solved with auto, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] double "apply" not solved with auto, Bart De Vylder, 06/14/2012
