coq-club - Re: [Coq-Club] Navigation commands forbidden in files
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Navigation commands forbidden in files
  • Date: Wed, 13 Jun 2012 17:17:00 +0200
Yes, I met the same problem while writing tutorials or material for
Lectures.
This pattern is useful for comparing various styles of definition.
Pierre
Quoting Adam Chlipala
<adamc AT csail.mit.edu>:
This is the new error message that Coq 8.4beta2 gives when using coqc to process files that use commands like [Reset]. Unfortunately, I've been relying on such commands in CPDT <http://adam.chlipala.net/cpdt/>, for didactic typesetting of command sequences that would never be present in polished source files in "real" projects. For instance, I will introduce a bad definition, work through examples showing why it is bad, and then [Reset] and redefine it.
Does anyone have suggestions on how to refactor to support 8.4beta2?
